SS-V: 5040 Residual Deformations in an Axially Loaded Plastic Bar
Test No. VNL05 Find residual deformations in a bar axially loaded beyond plasticity.
Definition
- Strength coefficient.
- Must be in the range [0,1].
- =0
- Material is perfectly plastic.
- =1
- Material is elastic.
The left end of the bar is clamped and the right end is loaded with force F.
- Properties
- Value
- 530 MPa
- 0.26
- Poisson's Ratio
- 0
The study was performed for the following load F values: 20000 N, 25000 N, and 30000 N
Reference Solution
One-dimensional analytical reference solution is described here.
- Total strain in the bar.
- Elastic component of the total strain.
- Residual strain.
- Bar cross-section area.
Results
Force F [N] | SOL Reference, Residual Displacement [mm] | SimSolid, Residual Displacement [mm] | % Difference |
20000 | 3.22 | 3.43 | 6.78% |
25000 | 9.16 | 9.172 | 0.13% |
30000 | 19.077 | 19.14 | 0.33% |
